Hi to all,
I developed an extension and want to publish it on my site. I followed the instructions that I’ve found in Examples - Apache OpenOffice Wiki
Everything seems to work fine until I put the file “extension.update.xml” in a site which requires http authentication. When I go to “Extension Manager” and check for updates, Libreoffice pops up an authentication form in which I have to enter the username and password for the http authentication. After that I obtain the following error:
Premature end of data in tag html line 2
Line: 16
Column: 1
This is the content of “extension.update.xml”
<?xml version="1.0" encoding="UTF-8"?>
<description xmlns="http://openoffice.org/extensions/update/2006" xmlns:xlink="http://www.w3.org/1999/xlink">
     <identifier value="it.example.example"/>
     <version value="1.0.0" />
     <update-download>
          <src xlink:href="http://www.example.it/updates/example.oxt" />
     </update-download>
</description>
The very same file deployed on a site which doesn’t require authentication works correctly.
I’ve also tried a mixed situation which is also working: if I put ‘extension.update.xml’ on a site which doesn’t require authentication, but the link to download the extensions points to a site in which authentication is required, by providing the correct login informations to libreoffice the extension is correctly downloaded.
I’ve tested it with Libreoffice 4.1.2.3 on a Windows 7 machine and with Libreoffice 4.0.3.3 on a Linux box
Do you have any suggestion on how to make autentication work also for the “extension.update.xml” file?
TIA, gtrev
