I have been researching this for days. None of the previously provided solutions work for me.
I import a Spreadsheet and in that process I am not given the option of picking a primary key. I also cannot find a place in the table edit to make one of the fields a primary key. One of the solutions I found said a primary key was needed to add rows. The table is created and I save it. I have tried not saving it too.
I want to insert additional rows to this table. I select insert and Records is grayed out. I go to the bottom of the table and try to add a row, that does not work either.
I tried creating a different table with the fields I need, and tried to paste in the rows from the spreadsheet. That locked up the program even though I waited 60 minutes.
I have right clicked on the table name and gone to Edit. I can’t change the properties. They are all greyed out.
I want to import spreadsheet data into a table and be able to use it like a table. Do I need to import differently? Is there a way to get these tables working so data can be inserted?
