I can’t build LibreOffice, because sw_ooxmlexport3.test fails. Using MBP retina, macOS 10.11.
warn:sw.core:73344:994414:sw/source/core/attr/calbck.cxx:170: a 12SwCharFormat client added as listener to a 12SwCharFormat during client iteration.
testFileOpenInputOutputError::Import_Export_Import finished in: 3556ms
/Users/markvecsernyes/lode/dev/core/sw/qa/extras/ooxmlexport/ooxmlexport3.cxx:588: Assertion
Test name: testTdf106974_int32Crop::Import
assertion failed
- Expression: sal_Int32( 40470 ) < aGraphicCropStruct.Right
- 39400
Test name: testTdf106974_int32Crop::Import_Export_Import
assertion failed
- 39398
Failures !!!
Run: 86 Failure total: 2 Failures: 2 Errors: 0
warn:fwk.desktop:73344:994414:framework/source/services/desktop.cxx:1068: Desktop disposed before terminating it
warn:vcl.schedule.deinit:73344:994414:vcl/source/app/scheduler.cxx:158: DeInit task: Timer a: 1 p: 1 svtools::GraphicCache maReleaseTimer 10000ms (0x7fad9e551920) (ignored)
warn:vcl.schedule.deinit:73344:994414:vcl/source/app/scheduler.cxx:174: DeInit active tasks: 1 (ignored: 1)
2017-11-02 19:15:59.921 cppunittester[73344:994414] *** -[NSAutoreleasePool release]: This pool has already been released, do not drain it (double release).
warn:unotools.config:73344:994414:unotools/source/config/configmgr.cxx:167: ConfigManager not empty
Error: a unit test failed, please do one of:
make CppunitTest_sw_ooxmlexport3 CPPUNITTRACE="lldb --" # for interactive debugging on OS X
make CppunitTest_sw_ooxmlexport3 VALGRIND=memcheck # for memory checking
/Users/markvecsernyes/lode/dev/core/solenv/gbuild/CppunitTest.mk:114: recipe for target '/Users/markvecsernyes/lode/dev/core/workdir/CppunitTest/sw_ooxmlexport3.test' failed
make[1]: *** [/Users/markvecsernyes/lode/dev/core/workdir/CppunitTest/sw_ooxmlexport3.test] Error 1
make[1]: *** Waiting for unfinished jobs....
Makefile:266: recipe for target 'build' failed
make: *** [build] Error 2
