I’m using Libreoffice 7.1.5.2 and HSQLDB 2.3.2, in the classic split database setup.
I’ve created a view that aggregates data from several tables, both for easy reference and because I was having trouble getting complex selections to work in forms. Data retrieval here works fine, the form displays as expected. However, I would like to also be able to insert or edit entries shown in the form like I can with real tables. I created several triggers, causing updates to the view to update data in the corresponding table (my view filters based on data from several tables, but inserts and updates only need to affect records in one table).
This now works as expected from SQL: INSERT commands on the view will propagate correctly to the source table. However the table in Base still has all editing controls greyed out and doesn’t seem to know that editing is possible now. Is there a way to get Base to recognize that a view is not actually read-only?
