Thanks for an immediate answer. I did waht you suggested setting the default values to 0. Also changed the format to EUR. Still didn"t work. What other field type can I use in this case? Do ypou have ang suggestions on how I can arrive at the totals?
Thanks a lot. Problem solved.
Btw, how can delete a macro the easiest way? Thanks.
That is a different topic from the original question and should be asked as a new question. Questions asked such as this will not be easily found by others looking for the same answer.
Not to stiff you on some type of answer, the easiest way is to go to the Basic IDE Tools->Macros->Edit Macros
and delete from there. If you are referring to the situation in your file, that is more complex and I don’t even know how you got it into that situation. That should be a different question.
Ok. Thanks.
