Hopefully, I have the terminology correct…
LibreOffice 7.0.6.2 ( 64bit) | Windows 10 | DRAW
Problem\Question:
In DRAW, how to create snap point, using a macro (VB this case).
 example. coordinates
 Position.X = 1.0
 Position.Y = 5.0
 (1.0, 5.0)
Connect/Position TextShape (Right-Center Glue Point) at Snap Point Object, and not the standard Top-Left gluepoint.
 Again, using a macro.
Also, to be able to apply the macro solution to other Shapes
