Values from linked cells not saving when spreadsheet is reopened
Recently switched to Libre from openoffice. I have a master file that references 20 or so other files. It works perfectly when I have the references updated automatically on opening. The problem is I don’t want to have them updated unless I choose to. They are relatively large files and it can take 10 minutes to do. I use this file often but don’t need it updated except for once a month. When I select the option to ask before updating it doesn’t load correctly. It doesn’t open the last saved values. It actually won’t open the same way twice. Some values will be there and some won’t…links are still there. I do have autocalculate on. I’m hoping I’m missing something obvious being new to Libre.
Yes, we also:
Please specify to all inquiries:
operating system
LibreOffice version (four-digit, e.g. 7.4.5.1).
file type in which saved your file
Thanks
It looks like this bug tdf#99572 ODS sheet with many external links from other Calc files does not stay updated after saving and reloading
Please add there your comment.
Are you able to reduce the issue to about three files, and attach them as samples, after depersonalising them.
Windows 11 Pro
Libre version 7.4.6.1
Saved as .ods
