Vba code of opening a save as dialog box and writing a string into it is not working in libreoffice
Dim vFile As Variant
 vFile = Application.GetSaveAsFilename(InitialFileName:=Sheets("SIMPLE").Cells(2, 2) & "_config.yaml",FileFilter:="YAML Config File (*.yaml), *.xlsb, All files (*.*), *.*",Title:="Save Config File As:")
If vFile <> False Then
    Call saveFile(vFile, yaml)
    MsgBox ("File Saved")
End If
Sub saveFile(fileName As Variant, content As String)
Dim fso As Object
Set fso = CreateObject("Scripting.FileSystemObject")
Dim oFile As Object
Set oFile = fso.CreateTextFile(fileName)
oFile.WriteLine content
oFile.Close
Set fso = Nothing
Set oFile = Nothing
As far as I know, VBA code cannot be executed in Libreoffice
