Recently upgraded from 5.2.4.2 (x64) running on Windows 10 (x64). HSQLDB Embedded
I have a database table that contains 5 fields specified as “YES/NO BOOLEAN”
Everything runs/looks fine in version 5.2.4. However in version 5.3.0 the Boolean fields have disappeared from forms and in a table view the columns are listed but the fields are empty. Running a query using the Boolean fields seems to work ok, indicating that the data is there but I just can’t see it - or enter it.
Am I missing a new setting/parameter someplace?
Additionally in both versions I have GL disabled and OpenCL disabled.
Would appreciate some guidance on this - TIA.
