In LibreOffice Calc, if you are not on the first A column, a vertical mouse (or touchpad) scrolling is scrolling first horizontally back to A and then it’s scrolling vertically as it should be.
This is COMPLETELY counter-intuitive. It seems specific to Calc as Write doesn’t behave the same (bad) way.
Where is the settings to change that behavior? I couldn’t find it.
