I’m a very experienced C++ coder so principles are fine, but I’m just starting to try to get into Vis Basic in Calc and fine details are not clear by a long chalk. I’m sure this is an easy fix for those who know VB but I have searched for hours to find out how to sort it out and can’t find anything relevant.
I’m writing my first function to simply explore how things work for a more ambitious project later. At the moment I’m exploring searching within a string and replacing characters. I have a problem very early on in the code where I call Calc’s Substitute( , , , ) function. It reacts as though SUBSTITUTE doesn’t exist and I don’t know where to go from there. The current code up to the error point is:
Function TestSetFuncs()
Dim TestValue, NewValue As String
Dim Position As Integer
TestValue = "4R7"
Position = Instr(TestValue, "R")
Substitute(TestValue, "R", ".")
End Function
Everything up to just after the Instr call is fine, the “R” is found and Position is passed the value 2, but Substitute blows up every time I try to step into it with error: “BASIC runtime error. Sub-procedure or function procedure not defined.” I must be doing something ridiculously simply wrong but I can’t for the life of me find it. Can anyone enlighten me please?
I’m sure I’ll be back!
