I’m starting to use functions typing SQL code in LibreOffice Base… however I see differences between the SQL code suggested by several websites and LibreOffice Base…
For example, at w3schools.com they would suggest me this code to introduce the current system date and hour into a field of my database (sorry for the fields are in Spanish)…
SELECT
ID_Empleados,
Nombre,
Apellido1ero,
Direccion,
NOW( )
PerDate
FROM
tbl_EMPLEADOS
Okay, that code will fail in LibreOffice Base, and it is SQL …
However, if I use " " then the code work…
This code will work in LibreOffice Base…
SELECT
“ID_Empleados”,
“Nombre”,
“Apellido1ero”,
“Direccion”,
NOW( )
“PerDate”
FROM
“tbl_EMPLEADOS”
So I really don’t know why do we have those differences and if LibreOffice Base is using a kind SQL following a certain standard or specification…
I find differences between the SQL code from w3schools.com and the SQL code implemented by LibreOffice Base
I’d like to find a website where may I see SQL functions with examples of code that works fine in LibreOffice Base, however that web site, offer me SQL code but … don’t work in LibreOffice Base due minor differences in the code notation, etc.
So what kind of SQL is using LibreOffice Base?
Could we tell me any website where may I consult the whole SQL functions, etc. but with code examples that work fine in LibreOffice Base?
Cheers
