When I type “i”(and) in writer it switches to “I”(AND) - how to fix that, 6.0.3.2 x64 PL
There’s more than one “path”/work-flow for this, but I think this one’s the simplest:
- Go to
Tools > Autocorrect > Autocorrect Options..., and ensure that the “Replacements and exceptions for language:” at the top of that window is set for “Polish”. (These settings operate on a per-language basis.) - Under the Replace tab (should be active), clear the “Replace” box and type in
i. - That ought to take you to the line that defines “i” as upper-case “I”, with it highlighted. If it isn’t, click on it.
- Click the
Deletebutton. - Clicl
OK.
Done. It is, of course, easily reversed.
To show the community your question has been answered, click the ✓ next to the correct answer, and (optionally!) “upvote” by clicking on the ^ arrow to express thanks. These are the mechanisms for communicating the quality of the Q&A in these systems. Thanks!
I have the same problem, but your solution doesn’t work for me. What are the other options you mentioned? I don’t know why, but in some Wirter files this problem appears, in others it doesn’t.
