Official LO Writer wiki says you can use “direct clear formatting” tool to clear character style from text but you don’t.
What’s wrong?
I use LO 4.3.7.2 for OS X and LO 4.2 for Linux
Thanks.
What’s wrong?
Thanks.
Hi Bruno Mendoza
You are talking about:-
Format
- Clear Direct Formatting
Ctrl+M
I use LO-4.4.3.2 under Linux & cannot confirm your report, Bruno (sorry). It works as expected for me, which is to return the formatting to the defaults of the style currently in force.
From the LO downloadable help text:-
Removes direct
formatting and formatting by character
styles from the selection. Direct
formatting is formatting that you
applied without using styles, such as
setting bold typeface by clicking the
Bold icon.
Thanks Alex,
I thought “Clear Direct Formatting” returns all selected characters to “Default Style” character style even after set a different “Character Style” from “Styles and Formatting” panel.
You are correct, Bruno - that is my reading of the LO help.
In general use, I find that Ctrl-M will remove other styles & formatting & send the text back to the default style on the paragraph. However, I tried a little test just now & it did NOT remove any formatting at all, whether by toolbar or by character style. Good lord! Looks like yet another bug.
You surely selected a portion of text before calling the ‘Clear direct formatting’ tool?
@Lupp I most surely did, yes. I’ve been watching this tool more closely since Bruno’s question & my initial reply. It simply does not work in the manner that the LO Help says it should. Also, as you say in your answer, applying a paragraph style (even if that is the style already in force) is far quicker. Which is silly.
“Clear Formatting Tool” removes character styles but it makes only in one way. Look at this link text
‘Clear Direct Formatting’, whether called by the shortcut Ctrl+M or in another way, does not set a default style. It simply clears format properties directly applied, mostly using one or another iconised tool or one of the format dialogues. The alternative to direct formatting is applying named styles. Format properties assigned this way are not afflicted by the procedure under discussion.
NB Page styles do not work this way. This may be related to the lacking inheritance feature. Any changes to the current page format becomes part of the named style assigned to the page and cannot be made undone by Ctrl+M. In other words: There doesn’t exist a direct formatting of pages.
That’s not true. You can stop setting character style to a string using Direct Formatting Tool but you can’t highlight some characters and removes its applied character style. This is very confusing.
Hi
As @Lupp said, it is not a bug but the expected behavior. Help has unfortunately not been updated and describes the former operation inherited OOo.
See tdf#31394
Regards
But… if you are writing some text, stop and set some character style, add some more characters to your text and then use “clear direct formatting” tool it will change character style to default.
Look at this video link text
I see what you mean, but context is different. Clear direct...
(or Ctrl+M) returns to the default style for what will be typed after. What I mentioned is different: select already typed text, use Clear direct...
remove bold applied with the format toolbar, not bold applied with Strong emphasis style.
Then official wiki help document about “direct formatting tool” is partly correct. You can remove a character style using “direct formatting tool” but you can’t highlight a string and use this tool to remove character style applied to it. It’s very confusing and I think it is a problem.
It seems to me that this was the meaning of the second sentence of my answer
