I apologize if this question has been asked but I’m a long time LibreOffice user and, for the last few weeks, whenever I try to print 12 Point Times New Roman type the resulting printout is far too small. Instead of printing 12 pt Times New Roman, I get 8 pt type. This happens with any new document I try to create and any old document that I try to print.
I’m using an HP3015. I’m about ready to give and go back to Word. I’m using LibreOffice Writer 5.2. I’m using a Lenovo
System Name	ME1713-43592L, OS Windows 7
Weird problems such as this are often fixed by returning to a Default Profile. Here is how:
Restore a Default Profile
Restore a Default Profile (the actions below are easily reversible). When you uninstall/update LO/OO it does NOT uninstall/delete the profile. The profile contains a user’s setup.
“If you notice any strange behaviour on LibreOffice, or simply it fails to start, the first thing to try is to reset the user profile.”
- Shut down LO/OO (also quickstarter)
- Find your profile
- Rename the dir
- Restart LO and/or Quickstarter
(on restart, LO will re-create the Profile directory + contents, using full defaults)
If this helps then please tick the answer ( )
…and/or show you like it with an uptick (∧)
Hello, Alex:
Thanks for the advice and links about the Profile but I made sure to select the proper “Windows” version of LibreOffice and all now seems right with the world.
