Will LibreOffice open and read old WordPerfect/Quattro Pro files?
I have a bunch of files on my old Dell computer that were written using Corel. That computer is dead but the files are stored on another backup drive. I don’t have Corel on my newer Mac. If I download LibreOffice, will I be able to read and copy those old files? Thanks!
Is anyone going to answer my question?
Hi jazzycat
Update 2015-10-8:
Yes, for both. Details here:-
Not too certain about the WP, yes to the Quattro Pro 6 files.
LO uses filters to get foreign-format files imported into it’s own ODF format. You can also write your own, but it is hardly a quick job. Stupidly, there seem to be zero lists of pre-written filters (something like 127) (in fact, 167). I’ve been bashing my head against the computer trying to suck a list out from the files on disk. I’ve had a little success:-
:~$ cat /opt/libreoffice5.0/share/registry/calc.xcd | tr '>' "\n" | fgrep -i Quattro
<node oor:name="Quattro Pro 6.0" oor:op="replace" oor:finalized="true" oor:mandatory="true"
Quattro Pro 6.0</value
QuattroPro Document</value
Then, if you want to explore further:-
:~$ cat /opt/libreoffice5.0/share/registry/calc.xcd | tr '>' "\n" | fgrep -i 'name=' | less
(and search on *oor:op="replace"*)
<oor:component-data oor:package="org.openoffice.TypeDetection" oor:name="Filter"
<node oor:name="Filters"
<node oor:name="DIF" oor:op="replace"
Now using:
:~$ cat /opt/libreoffice5.0/share/registry/calc.xcd \
| tr '>' "\n" \
| fgrep -i 'name=' \
| fgrep 'oor:op="replace"' \
| less
…get us a large listing (only 77, so some are missing):
<node oor:name="HTML (StarCalc)" oor:op="replace"
<node oor:name="OpenDocument Spreadsheet Flat XML" oor:op="replace"
<node oor:name="Lotus" oor:op="replace"
<node oor:name="MS Excel 4.0" oor:op="replace"
<node oor:name="MS Excel 4.0 Vorlage/Template" oor:op="replace"
<node oor:name="MS Excel 5.0/95" oor:op="replace"
<node oor:name="MS Excel 5.0/95 Vorlage/Template" oor:op="replace"
<node oor:name="MS Excel 95" oor:op="replace"
<node oor:name="MS Excel 95 Vorlage/Template" oor:op="replace"
<node oor:name="MS Excel 97" oor:op="replace"
<node oor:name="MS Excel 97 Vorlage/Template" oor:op="replace"
<node oor:name="Rich Text Format (StarCalc)" oor:op="replace"
<node oor:name="SYLK" oor:op="replace"
<node oor:name="StarOffice XML (Calc)" oor:op="replace"
<node oor:name="Text - txt - csv (StarCalc)" oor:op="replace"
<node oor:name="calc_HTML_WebQuery" oor:op="replace"
<node oor:name="calc_StarOffice_XML_Calc_Template" oor:op="replace"
<node oor:name="calc_pdf_Export" oor:op="replace"
<node oor:name="dBase" oor:op="replace"
<node oor:name="calc8" oor:op="replace"
<node oor:name="calc8_template" oor:op="replace"
<node oor:name="Calc MS Excel 2007 XML" oor:op="replace"
<node oor:name="Calc MS Excel 2007 XML Template" oor:op="replace"
<node oor:name="Calc MS Excel 2007 Binary" oor:op="replace"
<node oor:name="Calc Office Open XML" oor:op="replace"
<node oor:name="Calc Office Open XML Template" oor:op="replace"
<node oor:name="MS_Works_Calc" oor:op="replace"
<node oor:name="WPS_Lotus_Calc" oor:op="replace"
<node oor:name="WPS_QPro_Calc" oor:op="replace"
<node oor:name="Beagle_Works_Calc" oor:op="replace"
<node oor:name="ClarisWorks_Calc" oor:op="replace"
<node oor:name="Claris_Resolve_Calc" oor:op="replace"
<node oor:name="Great_Works_Calc" oor:op="replace"
<node oor:name="Mac_Wingz_Calc" oor:op="replace"
<node oor:name="Mac_Works_Calc" oor:op="replace"
<node oor:name="Apple Numbers" oor:op="replace"
<node oor:name="calc_DIF" oor:op="replace"
<node oor:name="calc_ODS_FlatXML" oor:op="replace"
<node oor:name="calc_HTML" oor:op="replace"
<node oor:name="generic_HTML" oor:op="replace"
<node oor:name="generic_Text" oor:op="replace"
<node oor:name="calc_Lotus" oor:op="replace"
<node oor:name="calc_QPro" oor:op="replace" oor:finalized="true" oor:mandatory="true"
<node oor:name="calc_MS_Excel_40" oor:op="replace"
<node oor:name="calc_MS_Excel_40_VorlageTemplate" oor:op="replace"
<node oor:name="calc_MS_Excel_5095" oor:op="replace"
<node oor:name="calc_MS_Excel_5095_VorlageTemplate" oor:op="replace"
<node oor:name="calc_MS_Excel_95" oor:op="replace"
<node oor:name="calc_MS_Excel_95_VorlageTemplate" oor:op="replace"
<node oor:name="calc_MS_Excel_97" oor:op="replace"
<node oor:name="calc_MS_Excel_97_VorlageTemplate" oor:op="replace"
<node oor:name="writer_Rich_Text_Format" oor:op="replace"
<node oor:name="calc_SYLK" oor:op="replace"
<node oor:name="calc_StarOffice_XML_Calc" oor:op="replace"
<node oor:name="pdf_Portable_Document_Format" oor:op="replace"
<node oor:name="calc_dBase" oor:op="replace"
<node oor:name="MS Excel 2007 XML" oor:op="replace"
<node oor:name="MS Excel 2007 XML Template" oor:op="replace"
<node oor:name="MS Excel 2007 Binary" oor:op="replace"
<node oor:name="Office Open XML Spreadsheet" oor:op="replace"
<node oor:name="Office Open XML Spreadsheet Template" oor:op="replace"
<node oor:name="calc_MS_Works_Document" oor:op="replace"
<node oor:name="calc_WPS_Lotus_Document" oor:op="replace"
<node oor:name="calc_WPS_QPro_Document" oor:op="replace"
<node oor:name="calc_Beagle_Works" oor:op="replace"
<node oor:name="calc_ClarisWorks" oor:op="replace"
<node oor:name="calc_Claris_Resolve" oor:op="replace"
<node oor:name="calc_Great_Works" oor:op="replace"
<node oor:name="calc_Mac_Works" oor:op="replace"
<node oor:name="calc_Mac_Wingz" oor:op="replace"
<node oor:name="calc_AppleNumbers" oor:op="replace"
<node oor:name="m1" oor:op="replace"
If this helps then please tick the answer (:heavy_check_mark:)
…and/or show you like it with an uptick ()
