have defined print range for printing on A5 paper. Used to work fine. Now printing choosing option ‘fit print range to width/height’ results in contents of page fitting vertically but so narrow on the width that the print is too small to read. What am I doing wrong?! Thanks
Play with the number pages for width/height or/and in Page tab change the orientation.
Edited.
Remember that page break only works with scale mode.
Thanks for the suggestions. Unfortunately, they did not work!
SBV
