I know you can disable automatic capitalization for certain words, but I’m having a few specific problems with capitalization that are driving me crazy:
- When writing a scientific document, I often have to use the lower-case letter “i”. I still want Writer to capitalize it, but is there a way to set writer to ignore the letter if I delete it and retype it? For instance, I would type the letter “i” and writer changes it to “I”. I then hit backspace twice to delete it and type “i” again. This time it should ignore the “i” like it does in Word or other similar programs.
- I know you can disable auto correction or capitalization of certain words, but it seems I’m running into a problem where Writer is automatically making a letter lowercase that doesn’t exist in the rules. For an example, I can’t type the two capital letters P and K, followed by a subscript “a” without writer trying to make the capital K lowercase. I can’t find a solution besides selecting the letter and making it uppercase explicitly. This takes a lot of time.
Any help would be greatly appreciated!
