Writer change case via Shift+F3 for all paragraph, not for selection
When I try to change case for individual words (highlighted) using Shift+F3, Writer change case for some other words in this paragraph. How can I change case only for highlighted text?
LO 7.1.0.3 (x64)
tdf#49033⁠
If this casing has any specific significance for you, put it into a character style and apply this style instead of Shift+F3. It is much more reliable and customizable.
To Mike: thanks, I’ll try extension from Mihail Balabanov
To ajlittoz: thanks, but this solution is not convenient for my case, because I already use a character styles in this text for another purposes and different character styles will conflict
No problems with Shift+F3 for me. LO 7.0.6.2 and 7.1.0.3 (x86) on Windows 6.1.
Could be there something related to the .doc(x) format?
To LeroyG: just tried with .odt - the same problem. As Mike mentioned in his comment, this is a notorious bug tdf#49033
