I’m posting this question because I have a strange problem.
Since I’ve installed LibO 4.1.x I have to rebuild all the piecharts built with Calc and embedded into Writer with a simple table.
In other words, I can insert any number of percentages into the piechart, but when I save the file in PDF format and then I reopen the document every piechart has only one percentage and no other ones.
I have to modify every chart manually and save them again, but when I reopen the file next time there are only one percentage again.
With LibO 4.0.x there wasn’t this problem.
These are some examples of my problem.
- this is how the piechart looks every time i open the document:
- this is how the piechart should be:
Have I to submit a bug for this problem?
