macOS Sequoia 15.7.3
Libre Office Version: 25.8.4.2 (X86_64)
Build ID: 290daaa01b999472f0c7a3890eb6a550fd74c6df
EPSON ET-2650
I’m trying to print Writer documents via a wifi connection to my EPSON printer.
The process is very variable. Some documents print promptly, some are very slow and some won’t print untill I turn off the printer and turn it back on again and reset the whole printing process.
I suspect it relates to one or more document settings as this problem occurs with documents originating from other PCs, usually written in word under MS Windows.
Any suggestions as to which document settings might be causing this?
Thank you.
