Hello everyone,
I have an issue with the way the writer makes line breaks. When I press ‘enter’ the space between the new and the old line is a bit too long. If I instead press ‘shift+enter’, the space is the way I want, but it is not a “complete break”, and that gives different formatting problems later on.
So, is it possible to change the settings in order to make sure that the enter-key start working in its traditional way? How?
Thank you very much for your time!
LibreOffice version: 4.3.4.1. (Swedish)
OS: OS X 9.5 (Swedish)
