mike@RPI4b3:~> uname -a
Linux MikesPI 6.1.0-rpi7-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (2023-11-24) aarch64 GNU/Linux
Version: 7.4.7.2 / LibreOffice Community
Build ID: 40(Build:2)
CPU threads: 4; OS: Linux 6.1; UI render: default; VCL: x11
Locale: en-US (C); UI: en-US
Raspbian package version: 4:7.4.7-1+rpi1+deb12u5
Intalled from XrayTool60_en.odt.
Following the instructions I pointed Xray to /usr/bin/firefox then
web searched “LibreOffice”+“Global Index A”+“MediaDescriptor” which took me to https://www.libreoffice.openoffice.org/api/docs/common/ref/index-files/index-1.html.
In Xray Configure and clickng on the ‘Use API from the Web’ button I paste the afore mentioned URL in the box and click OK.
The response comes back ‘This page is missing on the Web site :
https://www.libreoffice.openoffice.org/api/docs/common/ref/index-files/index-1.html’ but when I look at the page I find entries for ‘CHART’ and ‘chart’.
In my code the initial line was ‘Xray( Chart )’, thinking the search might be case sensitive I switched it to ‘Xray( chart )’ but that made no difference.
I’m not yet ready to try MRI but if anyone can point me in the right direction for getting Xray working I would appreciate it.
Thanks,
Mike
It’s strange how you decided to use LibreOffice 7.4.7 - it’s so young, just two years old?
