LibreOffice Base does not come with Lubuntu 18.10 Desktop 32 Bit
asked 2018-11-28 03:41:46 +0200
lonk gravatar image
updated 2020-09-03 10:41:55 +0200
Alex Kemp gravatar image
Every application of LO comes, except LO Base.
If I have to install by myself, what should I do?
1 Answer
answered 2018-11-28 03:53:29 +0200
Ratslinger gravatar image
Every Ubunbu based system (and some other Linux distros) seem to not include Base in the initial default setup. Don't have a reason why. You can typically install it from their Software Manager.
If you are in fact using a 32 bit OS you may have other problems with Base. That has to do with the Kernel. See this post for a fix -> How do I get Base to work under Lubuntu 16.04?.
Thank you so much for your help.
lonk gravatar imagelonk ( 2018-11-28 16:44:04 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2018-11-28 03:41:46 +0200
Seen: 212 times
Last updated: Nov 28 '18
