Every application of LO comes, except LO Base.
If I have to install by myself, what should I do?
Every Ubunbu based system (and some other Linux distros) seem to not include Base in the initial default setup. Don’t have a reason why. You can typically install it from their Software Manager.
If you are in fact using a 32 bit OS you may have other problems with Base. That has to do with the Kernel. See this post for a fix → How do I get Base to work under Lubuntu 16.04?.
Thank you so much for your help.
