Calc: Exclude rows from INDEX() reference
asked 2020-10-16 00:18:11 +0100
vxky33x0egwnf4 gravatar image
updated 2020-10-17 20:33:42 +0100
Working on Sheet2, I can use the following formula to look up the "Sheet2.B1"th match in Sheet1, column B corresponding to Sheet1, column C:
{=INDEX($Sheet1.$B$1:$B$9,SMALL(IF($Sheet1.$C$1:$C$9=$A2,ROW($Sheet1.$C$1:$C$9)-ROW($Sheet1.$C$1)+1),B$1))}
I'd like to exclude rows from the lookup conditioned on the corresponding values in Sheet1, column A. For example, IF $Sheet1.$A$1:$A$9=0 THEN *exclude from row array*. I can achieve this by using Data > More Filters > Standard Filter..., copying the filtered rows to a new sheet, and using the formula above on it. However, I'd like to manage without duplicating any data.
Thanks in advance.
Edit: For example, I'd like to achieve the result in Sheet2_1 without having to filter and copy the data in Sheet1 to Sheet1_1.
Did not achieve result
Bad workaround
Example worksheet
1 Answer
answered 2020-10-16 19:08:05 +0100
m.a.riosv gravatar image
updated 2020-10-17 20:33:48 +0100
A sample that I think does what you like.
image description
Maybe with a pivot table it's easier and can be filtered as you like.
Pivot table sample
Thanks for your efforts, @m.a.riosv . I am not yet sure this meets my requirements, but I will continue to review it. I have edited my OP to include my own example.
vxky33x0egwnf4 gravatar imagevxky33x0egwnf4 ( 2020-10-17 19:44:17 +0100 )edit
Login/Signup to Answer
1 follower
Asked: 2020-10-16 00:18:11 +0100
Seen: 29 times
Last updated: Oct 17
