For example my document has a block of text that contains a block of text from another document. I want now to assert my document’s text format onto the combined block.
I press F11 to raise the Styles dialog.
I select the block, click on Text Format, double click on Text Format. Press Return.
No effect.
Is this expected behavior? Have I missed a step?
to the left and, karma permitting, upvote it. If this resolves your problem, close the question, that will help other people with the same question.
