One of those broken clipboard destroyers (aka “managers”) again.
@erAck Unfortunately it doesn’t help in my case since I don’t have the Gnome Clipboard Indicator installed.
You may have any other broken clipboard manager installed.
@erAck Mint Cinnamon doesn’t come installed with a default clipboard manager, and I never installed one, so unlikely.
Same problem windows10. If you do not use a clipboard manager you are not aware of the problem/ difference from Libreoffice calc 24.x.
With Ditto or copyq when you copy multiple cells, there is a strange behaviour.
For example If
1 you copy multiple cells
2 you open ditto
3 you paste the first entry
It is pasted an image of the cells.
I managed to solve the problem in KDE Plasma by disabling the clipboard viewer in the tray: right click on the “show hidden icons” button in the system tray, click on “Configure System Tray”, select the tab “Entries”, then scroll to find “Clipboard” and disable it.
