This seems like a huge UI bug. I entered some data and then tried to sort it. LibreCalc sorted it wrong. Using the internet I was able to find many other people who had this error before me. The problem is invisible until the user presses “Ctrl-F8”, or goes to the View Menu and selects “Value Highlighting”. However that doesn’t fix the problem, only reveals the issue. The obvious solution of highlighting the column or columns and Formatting the Cells to all be the same data type doesn’t have any effect. The solution I found in the forums works, but is very esoteric; I imagine for a regular user this would seem like wand waving and magic words:
If I understand this, the Find and Replace operation takes the text of the cell and re-renters it allowing the data type to be reset to the default type for the column.
This is a major UI bug. Is there something I missed?
If you are a user and you agree this is terrible default UI behavior, and that such a strange esoteric operation to correct the error being the only (?) option is also terrible. Please help me and speak up! Leave a comment, or help me submit a bug report.
Thank you!
But I wouldn’t ship them by default.
