Converting VBA Macro to Basic LibreOffice Macro
I need to know, how to convert the following VBA macro/function from Excel (below). When I opened it in LibreOffice this is what it displayed and I need to convert this script. Would like to use it with LibreOffice.
Your help would be appreciated. Thanks
Below is the VBA Script:
Rem Attribute VBA_ModuleType=VBAModule
Option VBASupport 1
Function ConcatIf(ByVal compareRange As Range, ByVal xCriteria As Variant, Optional ByVal stringsRange As Range, _
                            Optional Delimiter As String, Optional NoDuplicates As Boolean) As String
Dim i As Long, j As Long
With compareRange.Parent
Set compareRange = Application.Intersect(compareRange, Range(.UsedRange, .Range("a1")))
 End With
If compareRange Is Nothing Then Exit Function
If stringsRange Is Nothing Then Set stringsRange = compareRange
Set stringsRange = compareRange.Offset(stringsRange.Row - compareRange.Row, _
                                            stringsRange.Column - compareRange.Column)
For i = 1 To compareRange.Rows.Count
    For j = 1 To compareRange.Columns.Count
        If (Application.CountIf(compareRange.Cells(i, j), xCriteria) = 1) Then
            If InStr(ConcatIf, Delimiter & CStr(stringsRange.Cells(i, j))) <> 0 Imp Not (NoDuplicates) Then
                ConcatIf = ConcatIf & Delimiter & CStr(stringsRange.Cells(i, j))
            End If
        End If
    Next j
Next i
ConcatIf = Mid(ConcatIf, Len(Delimiter) + 1)
End Function
Hoping to get a response
Welcome @Flds !
Tell me please, did you write this yourself? Then you can probably explain the purpose of these lines:
The thing is that without these three lines the macro works fine. You just need to specify the ranges exactly, and not rely on the fact that this function will work even with incorrect data.
Additionally to @JohnSUN comment:
Instead this VBA-garbage, try native Calc-Functions in your Spreadsheet like:
=TEXTJOIN( delimiter ; 0 ; UNIQUE( FILTER(…)))
Hi JohnSUN,
Thank you for your quick response.
No, I did not write this script myself. I do not know VBA. I got help years ago.
The purpose of this was. I had created an Excel sheet, where I entered the birthdays and anniversaries of friends and family. So when I open this file the name of the persons birthday or anniversary appears on the top of the spreadsheet.
The spread sheet has the following columns. Name, Last Name, DoB, etc.
John, the 3 lines you sent, where should I insert them and do I have to delete any lines on the existing script I sent. Your help would be appreciated.
Thanks
Hi Karolus,
Thanks for your response. I do not understand what this line is. Do I need to inserte it in the script I sent.
Thanks
If you don’t care what is written in the code, then I suggest adding this function to your macros:
Function ConcatIf2(aCompare As Variant, xCriteria As Variant, Optional aStrings As Variant, _
Dim i As Long, j As Long, k As Long, m As Long, iRows As Long, iCols As Long
Dim aResult() As String, bNotFound As Boolean
	If IsMissing(NoDuplicates) Then NoDuplicates = False
	If IsMissing(Delimiter) Then Delimiter = ""
	If IsMissing(aStrings) Then aStrings = aCompare
	If UBound(aCompare,1) < UBound(aStrings,1) Then iRows = UBound(aCompare,1) Else iRows = UBound(aStrings,1)
	If UBound(aCompare,2) < UBound(aStrings,2) Then iCols = UBound(aCompare,2) Else iCols = UBound(aStrings,2)
	ReDim aResult(iRows*iCols)
	m = -1
	For i = 1 To iRows
	    For j = 1 To iCols
	        If (aCompare(i, j) = xCriteria) Then
        		m = m + 1
        		aResult(m) = aStrings(i, j)
        	EndIf
	    Next j
	Next i
	If m+1 Then
		ReDim Preserve aResult(0 to m)
       	If NoDuplicates Then
			k = 0
			For i = 1 To m
	       		bNotFound = True
        		For j = 0 To k
        			If aResult(i) = aResult(j) Then
        				bNotFound = False
        				Exit For
        			EndIf
        		Next j
        		If bNotFound Then
        			k = k + 1
        			aResult(k) = aResult(i)
        		EndIf
        	Next i
			ReDim Preserve aResult(k)
		EndIf
		ConcatIf2 = Join(aResult, Delimiter)
	Else
		ConcatIf2 = ""
	EndIf
End Function
This code is a little longer than your original macro, but will run faster.
NO, you should use it directly in the sheet with your customized arguments.
  • or
    ⇒ Data ⇒ Filter ⇒ …
Hello John,
Thank you for your code, I added it to my macros, I get error messages. I am attaching the file which will give you a better idea of what I am looking for. I am not sure if the macro/functions will work when you open the file.
Test_LO-1.ods (89.0 KB)
Thanks
Hi Karolus,
Thank you for your reply. I don’t understand what that (> Data > Filter >) is.
However, I have attached the Event file, which may give you an idea of what I am looking for.
Thanks
Yes, you are right - they did not want to work. But you must admit that these macros worked for 20 years, survived several versions of Excel - this is a very good indicator. Dave Peterson wrote this code well.
In my file, all of its code is removed, leaving only one macro, which actually prepares warnings about future events. Try this Test_LO-2.ods (61.0 KB)
replaced makro by native Calcformulas:
convert_makro_to Formula_125416.ods (59.7 KB)
Hi John,
Fantastic! the macro worked perfect. Thank you so much for your time and efforts in helping me. If you were my neighbour, I would have bought you a coffee or a beer. Wish I could learn how to code?
Thanks once again
Hi Karolus,
Grate! Thanks a lot for your time and efforts. Your formula works well a small adjustment may be required, when I change the first 2 lines to today’s date, but I get a “Err:533” on day 2 and day 3. These boxes appear blank. I am not sure if I use an “IF” function, it may work.
However, I am happy with the formula.
Thank you once again.
Great Correct my spelling
