This has been asked before, but it was never answered.
The last LO Writer guide (p. 389 in the PDF) mentions that in order to restart page numbering inside a master document one needs to create a heading style with outline level set to Level 1 and which inserts a page break with a specific page style and sets the page number to 1.
I have created such a heading style in my document’s template, but page numbering does not restart.
If I apply the same style to a paragraph of a regular document, it works.
Any ideas?
(using v5.4.3.2)
EDIT:
Hi Jim,
Unfortunately my ISP is having problems at the moment and it would take forever to upload my thesis at my current speed. I’ll try to explain what I have done.
I started by creating a template and from that template the master document and all the sub-documents.
Whenever I wanted to add or modify a style, I did it in the template and the files were updated the next time they were opened.
I wanted the numbering to restart with Arabic numerals at the preface, which is a sub-document.
I created a heading style with its outline level set to Level 1. In the “Text Flow” tab I have the style insert a page break before it, with a specific page style and the page number set to 1.
All the sub-documents and the master document were updated to use the newer version of the template and I set the very first paragraph of the preface to that heading style.
In the master document, the numbering will not restart. If I apply the heading style somewhere in a sub-document (or a new document from that template), it does. It also restarts if I apply the heading style to a later part of the preface sub-document, but not to the first line. Although in that case, my first preface page gets the number 0… I can only get it to work if I add a blank page before the actual first page of the preface.
