Error saving - General Error. General input/output error asked before
Hi
On Linux Mint saving any LibreOffice document on our samba share gives this error. I can edit other files on the share. I can copy/cut/paste any file to the share.
I have no trouble saving LibreOffice docs on the share from a Windows machine.
LibreOffice was installed with Linux Mint 22.3 - Cinnamon 64-bit a few days ago. I have uninstalled and reinstalled LibreOffice but the problem persists.
Version: 24.2.7.2 (X86_64) / LibreOffice Community
Build ID: 420(Build:2)
CPU threads: 22; OS: Linux 6.14; UI render: default; VCL: gtk3
Locale: en-AU (en_AU.UTF-8); UI: en-US
Ubuntu package version: 4:24.2.7-0ubuntu0.24.04.4
This same issue was raised with the same title in March 24 here but didn’t get a response.
Is there a solution?
Thanks
maybe related to 115747 – Can't edit file on samba shares (see comment 28) (fstab nobrl workaround)
Thank you for your response. I mount the samba share in the terminal
sudo mount.cifs //192.168.2.1/Files/ /home/user/Files -o user=user,vers=2.0,nobrl
but still LibreOffice opens in read-only mode and cannot save to the share
you may try to investigate around → How to disable file locking on linux (Ubuntu) - Permanently
next (tedious) step : strace(1) - Linux manual page
e.g. strace -o lo.log -f -e access,open soffice
I set org.openoffice.Office.Common | Misc | UseLocking to false but it didn’t solve the problem.
I did use the Linux Mint Desktop Launcher widget to create a shortcut to the samba share and I can now edit documents on the share with LibreOffice.
So it looks like this is not a LibreOffice issue but rather an issue with how the share is mounted. I’ll take that up elsewhere and close this ticket. Thank you very much for your assistance.
