I have a spreadsheet of a corrupted Family Tree database that I have put into some reasonable order. I now have as one of the columns (D) the Chart number and Sub-category that each record belongs to.
I need to sort this spreadsheet into the Chart number order and dates in other columns as sub-keys. The mixed numeric and alpha in this column doesn’t sort correctly.
Examples of the numbers used in this column are :-
1
4A/K
6
6A
16A
22A?
23?
234A
(many are blank )
The ? I presume is where the Chart can’t be defined.
The column in the chart starts at D2:D4340.
If I insert a new column after D ie E - I want to separate the alpha letters (including the ?) into the new column, leaving the numeric numbers in the original column D and all the alpha letters (A-Z and / and ? etc )
Where there is no alpha letter following a number the new cell in column E should be blank.
Where the cell in D is blank then both cells will be blank.
I’ve have in the past made a little use of string functions but I need help with this.
Thank you
Garth
