How do I copy than paste a formula to multiple cells without the formula changing
If I try to copy and paste a formula, the formula changes to match the next row. How do I paste the same simple formula into many cells with out it changing.
example: =IFS(B109=0,Q2,B109=1,Q3,B109=2,Q4,B109=3,R2,B109=4,R3,B109=5,R4)
Each result (i.e. Q2, Q3 Q4 etc.) has a different text that gets placed into the cell depending on the number typed into B109 or B110 or B111 etc.
And, by the way, if I every make it through the tags and the reCaptcha, I will probable never use this site again. It is a waste of time trying to get verified that I am not something from outer space. The thing keeps coming up in a different langue. And the requirements for tags is ridiculous. it is never satisfied.
In the help it’s explained how to do it.
Addresses and References, Absolute and Relative
Hi
If the question is not about absolute addressing here is how I proceed in this case:
Click in the formula bar, Ctrl+A, Ctrl+C, Esc
That’s it just paste, the formula is not changed…
Regards
