How to change background color of comment(ctrl+alt+c) & is there any other feature like comment that can be hide-unhide “on click”?
I found in options, it allows to change the bright yellow color of notes in Spreadsheet. Which option do i use to change bright yellow color of comment in Impress?
Please help.
Libreoffice 3.6 IMPRESS
Thanks for replying CyanCG.
“…comments created with the “change tracking feature?” are assigned a color according
to the editor who produced the comment. This color can be changed on a per-user
basis”
I am the sole editor of the odp file, but how do i change the bg color of the comment box. It is so bright yellow. Hurts the eye.
“To answer your other question,… one can create text frames and create a style for
them to have them displayed as marginal notes. Different styles can be created for
different note colors and each style can be easily modified to toggle the
display/hide property.”
I am searching for what you said, but nothing relevant comes up or maybe i missed. Could you please provide link to this feature’s information on http://help.libreoffice.org.
