The AccessibleSpreadsheet and AccessibleCell interfaces give a variety of information about layout of cells of active sheet of Calc document on the screen.
There was no mention of these interfaces on the forum before this topic.
To work with these interfaces, it is proposed to use a set of functions below.
Usage example.
'Shows the screen coordinates (in pixels) of the upper-left corner of the selected cell
Sub ShowScreenCoordinates
Dim oDoc, oCell, oAccCell
oDoc=ThisComponent
oCell = oDoc.CurrentSelection().getCellByPosition(0,0) ' first cell in selection
oAccCell=GetAccessibleCell(oDoc, oCell) ' AccessibleCell
With oAccCell.LocationOnScreen
MsgBox "Screen coordinates of selected cell (pixels): X=" & .X & " Y=" & .Y
End With
Tools.
' Tools for AccessibleSpreadsheet and AccessibleCell interfaces
' By @sokol92
' Returns object (supports com.sun.star.AccessibleSpreadsheet interface) corresponding to active sheet of Calc document.
' - oDoc Spreadsheet document object.
Function GetAccessibleSpreadsheet(ByVal oDoc) As Object
Dim oAccDoc
GetAccessibleSpreadsheet=Nothing
oAccDoc=FindAccessibleRole(oDoc.CurrentController.ComponentWindow.AccessibleContext, 84) ' 84 DOCUMENT_SPREADSHEET
If Not (oAccDoc Is Nothing) Then GetAccessibleSpreadsheet=FindAccessibleRole(oAccDoc.AccessibleContext, 58).AccessibleContext ' 58 TABLE
End Function
' Returns object (supports com.sun.star.AccessibleCell interface) corresponding to cell of active sheet.
' - oCell Cell of active sheet.
Function GetAccessibleCell(ByVal oDoc, ByVal oCell) As Object
Dim oAccSpreadsheet
GetAccessibleCell=Nothing
If oCell.SpreadSheet.Name<>oDoc.CurrentController.ActiveSheet.Name Then Exit Function
oAccSpreadsheet=GetAccessibleSpreadsheet(oDoc)
If Not (oAccSpreadsheet Is Nothing) Then GetAccessibleCell=oAccSpreadsheet.getAccessibleCellAt(oCell.CellAddress.Row, oCell.CellAddress.Column).AccessibleContext
End Function
' Hierarchically search AccessibleContext for role value.
' - oAccContext Object (supports AccessibleContext service).
' - role role value.
' If the object has more than 500 child objects, then the child objects are not processed.
Function FindAccessibleRole(ByVal oAccContext, ByVal role As Long) As Object
Dim oAccChild, oResult, i As Long, j As Long, n As Long
FindAccessibleRole=Nothing
n=oAccContext.AccessibleChildCount
If n=0 Or n>500 Then Exit function
For i=0 To oAccContext.AccessibleChildCount-1
oAccChild=oAccContext.getAccessibleChild(i).AccessibleContext
If oAccChild.AccessibleRole=role Then
FindAccessibleRole=oAccChild
Exit Function
End If
' recursion
oResult=FindAccessibleRole(oAccChild, role)
If Not (oResult Is Nothing) Then
FindAccessibleRole=oResult
Exit Function
End If
Next i
End Function
' Hierarchically search AccessibleContext up to root object.
Function FindAccessibleRoot(ByVal oAccContext) As Object
Dim oAccParent, i As Long
oAccParent=oAccContext.AccessibleParent
Do While True
FindAccessibleRoot=oAccParent
i=i+1
oAccParent=oAccParent.AccessibleContext.AccessibleParent
If oAccParent Is Nothing Or i>100 Then Exit Do
Loop
End Function
