If I add an image, add a Caption to it, let’s say “test” and choose to insert a Field with its name afterwards with “Category and Number” it will output as it should "Figure ". However if I change the label from Figure to Figura , the field will only read . If I change it back to Figure the field will again update accordingly.
Questions:
Is there any way to make it work as it should?
Is there any way to update category names and keep the insert field functionality work as expected?
Demo attached: test.odt
PS: To be noted that the initial request stated that renaming from Figure to Figures does not work as expected, while it does, as pointed by @ajlittoz in comments.
