I found only how to show or hide grouping. How can I write macro to group columns or rows ?
Hallo
def example_group_hide_show(*_):
sel = doc.CurrentSelection
r_addr = sel.RangeAddress
sheet = sel.Spreadsheet
sheet.group(r_addr,1) # 0→group columns, 1→group rows
sheet.hideDetail(r_addr) #collapse
sheet.showDetail(r_addr) #un-collapse
LibreOffice BASIC, please.
Not Python
@lonk You may not believe it, but the BASIC code will be the same:
Sub example_group_hide_show()
doc = ThisComponent
sheet.group(r_addr,1) '# 0→group columns, 1→group rows
sheet.hideDetail(r_addr) '#collapse
sheet.showDetail(r_addr) '#un-collapse
And the answer to your question is this line:
@JohnSUN
How can I change from CurrentSelection to getCellRangeByPosition ?
Sub GroupColumns
Dim doc As Object
Dim sheet As Object
Dim r_addr As Object
doc = ThisComponent
sheet = doc.CurrentController.ActiveSheet
r_addr = sheet.getCellRangeByPosition(1, 0, 1, 0)
sheet.group(r_addr, 0) '# 0→group columns, 1→group rows
Add .RangeAddress
r_addr = sheet.getCellRangeByPosition(1, 0, 1, 0).RangeAddress
For .group() you need CellRangeAddress
youre a proficient copy&paste-coder…are you??
If you think the OP is more BASIC-oriented, then maybe along with a Python solution include a hyperlink to a 101 on adding a Python macro to an ODS file. Win a convert.
