I cannot get a UK English spellchecker which does not also include US English spelling. This was not a problem with LibreOffice 3 as the standard English UK spellchecker worked perfectly but this is not the case with LibreOffice 4.
Is it possible to replace the dictionary in LibreOffice 4 with the one in LibreOffice 3? If so, where is the spellchecker dictionary located in LibreOffice 3 (using Ubuntu [Zorin 5]) so I can, perhaps, copy it or could you make it available on line so that I can download it?
I’m now using Mint 15 and the and LibreOffice Version: 4.1.5.3, Build ID: 1c1366bba2ba2b554cd2ca4d87c06da81c05d24
Simple examples: neighbor; labor, center, color are not picked up as incorrect although, of course, they are incorrect in a UK English dictionary.
Thank you in anticipation of your attention.
Baz
