I just installed Libreoffice 4.0.1.2 I have been wanting to use Base to access our postgresql DB. I have tried in previous versions too with no success. When I set the form up with the Wizard I used the radio button “This form is to display all data” and did not select any of the checkboxes below it.
However when I finish the form creation and test it I discovered that I cannot edit or create records. I am able to do so in Access.
Take a look to the second answser in this thread:
