Found this thread looking searching for functions not computing. Thanks for the info on the cached values. Will dig into my generator software and see if there is anything I can do to disable this.
import xlsxwriter
# Create a workbook and add a worksheet.
with xlsxwriter.Workbook('Expenses01.xlsx') as workbook:
worksheet = workbook.add_worksheet('Tab33')
# Some data we want to write to the worksheet.
items = ('Rent','Gas','Food','Gym','Total')
values = (1000, 100, 300, 50, '=sum(B1:B4)' )
for c, data in enumerate((items, values)):
worksheet.write_column(0, c, data=data)
That in a comment says âIt then sets a global flag in the XLSX file to say that all formulas and functions should be recalculated when the file is openedâ. Which here is <workbook> child
<calcPr calcId="124519" fullCalcOnLoad="1"/>
Calc so far does not evaluate that and probably could.
Update 2022-08-08T16:27+02:00
This is tdf#144819.
⌠which then could allow us to add âFollow document settingâ to the ârecalculate on loadâ option - and make it the default
