I am using Ubuntu 14.04 and LibreOffice 6.3. I manage to extract first word with the following formula thanks to AskLibreoffice =REGEX(A1,"^(\w+).* Vs (\w+).*","$1 Vs $2")
Now I want to extract first two words in case the first word is Mr. Mrs. Dr. M/s etc. For example if the data is Mr. Aniruddha Mohod Vs Dr. Amitabh Bachchan the result should be Mr. Aniruddha Vs Dr. Amitabh
What about the “first two words” of Prof Dr. Dr. von der Pfordten ?
Trying to get something meaningful from a compound requires to know a very strict assured syntax.
Hi @AniruddhaMohod, with the following function you achieve your result:
=REGEX(A2,"^(\w+\.? \w+).* Vs (\w+\.? \w+) .*","$1 Vs $2")
However, the function is not compatible with your previous function. It cannot do both.
Try this.
=REGEX( A1 ; "(((\w+\.|M/s) )?\w+).* Vs (((\w+\.|M/s) )?\w+).*" ; "$1 Vs $4" ) |
And, Corresponding to future questions.
Ask_86222_Regex_Vs.ods (36.6 KB)
That expression unnecessarily uses too many capturing parentheses, which slow down processing and makes counting the captured grouping harder. Can be enhanced to this:
=REGEX(A1; "((?:(?:\w+\.|M/s) )?\w+).* Vs ((?:(?:\w+\.|M/s) )?\w+).*" ; "$1 Vs $2" )
I learned.
Thank you erAck.
