I try to use the Libreoffice remote app on android. A connection with WiFi works without problems, but connecting over Bluetooth does not work. Steps how I try it:
- Connecting my laptop with my phone over bluetooth.
- Testing the connection
e.g. I can send files from laptop to phone. - Opening my presentation with libreoffice impress.
- Opening the Libreoffice remote app on my phone
- Choose my laptop in the Bluetooth tab
- Got an error message
What I tried to fix the problem so far:
Checked that the setting for the remote is enabled (like it is mentioned in the error message) - Starting libreoffice with sudo (so that their are no permissions missing)
- Looking for similar questions here:
- Bluetooth setup fails for Impress Remote app on Nexus 6 phone - I tried restarting after getting the error in the app and also before choosing the laptop in the app
- Bluetooth connection failed on remote control impress - I set the device my phone as trusted the device on my laptop (in blueman).
Details about my software version:
Laptop
OS
Version Linux Mint 21.2 Victoria 64-bit
Kernel Linux 5.15.0-92-generic x86_64
MATE 1.26.0
Libreoffice
Version: 7.3.7.2 / LibreOffice Community
Build ID: 30(Build:2)
CPU threads: 4; OS: Linux 5.15; UI render: default; VCL: gtk3
Ubuntu package version: 1:7.3.7-0ubuntu0.22.04.4
Phone
OS
/e/OS 1.19.1-s (Android 12)
App
org.libreoffice.impressremote 2.6.1 (30)
What can I try to get the Bluetooth connection with the app running?
