Hi everyone, am having a problem with a particular manual column break in the following document:
NEW List of aspects to consider whilst practicing drums.odt
I can’t seem to get the column to break in the third column at the cell with the grey background that reads “TIMING”.
I want it to be at the top of the 4th column.
I have tried inserting manual column breaks in various places- I would have thought that positioning the cursor to the left of the “TIMING” text then inserting a column break there would have done the job, based on the following information:
“Column Break
Inserts a manual column break (in a multiple column layout), and moves the text found to the right of the cursor to the beginning of the next column. A manual column break is indicated by a nonprinting border at the top of the new column.”
Source: Insert Manual Break - LibreOffice Help
But apparently not as nothing happened as a result. Clearly I don’t understand how these breaks work well enough.
If someone could please explain where the manual break should be inserted and why then that would be swell!
Thanks helpful people!
