Please need help with Match Cells conditional format, please see attached file for example
How do I color background in G23 when it matches EXACT number in ROW M8:M17
M8:M17 isn’t ROW. Please write your question more clear
Use the following formula for conditional formatting: =MATCH(G23;$Sheet1.$M$8:$M$17;0)
Thank you for the reply,
I’m looking to change the background color when column G numbers match column M
This script shows only numbers that match and omits everything else.
I have a set of numbers in Column G & M, if G matches numbers in M then the background cell will change color
This is what i need. changing background
I found a work around but I have to create a conditional formatting for each cell
G23 = M8 color green
G23 = M9 color green
Are you looking for $G$23=M8 ?
