After a LibreOffice crash while I had been working on a large document for several days, I found myself with a recovery of this same document which did not correspond to my last work on it. This was a backup made about 20 hours ago.
I decided to look in the advanced options and backups without success, falling back on this same backup. My hypothesis is that I made the mistake of not manually saving my file, absorbed by my work and that the crash caused me to lose this automatic backup carried out by LibreOffice.
I come to you to ask for help from the community on the possibility of finding this automatic save even if it no longer seems visible on LibreOffice anymore.
Thank you in advance for your possible response and have a good day, hoping that yours is better than mine
