sorry/pardon for my bad englisch communication/conversation
that’s an very interesting exercise/question to difference in math. modus or (various) µC-programming modi or logical modus
so i try to explain out of my programmers viewpoint to approach one (of many) possible solution:
logical task: µC-programming
int x //variable: -32768…+32767 == „small-integer“ 2 Bytes//
int a_n //listed in table or matrix, /wobei/within/ n == „position number in list“//
cases: //successive read out! - - - cases in CALC: „=IFS()“//
-.1. x == a_n, TRUE ⋎ FALSE (boolean) //== : equal to / ⋎ : logical OR//
-.2. x != a_n, TRUE ⋎ FALSE (boolean) //!= : logical NOT//
-.3. x > a_n, TRUE ⋎ FALSE (boolean) //> : greater than//
-.4. x < a_n, TRUE ⋎ FALSE (boolean) //< : lower than//
-.5. x != int x, ERROR ⋎ NaN //NaN : not a number, but a value how 4.75 decimal//
- break; //do not drive into a infinite loop if fault in all above cases!//
for
a_1 = 682
a_2 = 657
a_5 = 636 //switched with another position//
a_4 = 645
a_3 = 654 //switched with another position//
// i have switched the position of a_3 to a_5 for testing clockwise ubwards-counting AND anti-clockwise downwards-counting for any failure!//
checking listet words/expressions/values a_n to validity:
- observe the downwards counting in listed int-values!
- try testing in transforming to upwards counting (= standard listing) *]!
- search for a deviated counting punched out of curved/lined seriality!
- search for a slipped letter or invisible sign or a undesirable character!
*] because some CALC-functions need a positive succession/sequence like: 1,2,3,4,…,9,10,11,…, that can failured while counting: 1, 10, 11, 12, …, 19, 2, 20, 21, …//
math. task:
f(x) = ??? //function to explane/express a infinite curve/line within 2 dimensions of decimal numbers f(x_n) = a_n(x|y)//
//visualize with every diagram program//
1_LibreOffice-CALC_gelistete Werte abfragen nach identisch UND angenähert höher ODER angenähert niedriger_iN ARBEiT-v0000.ods (38.2 KB)
1_LibreOffice-CALC_gelistete Werte abfragen nach identisch UND angenähert höher ODER angenähert niedriger_iN ARBEiT-v0000.pdf (110.1 KB)
something a little crumb you will/can used.
that’s only a tiny look in µC-programming for just as much understand the CALC-operations/functions/algorithms :: do not despair! and formulate any abstrus question into my belly!
much greetings/hello out of Deutschland (Allemand, Германия, germanskyji, Njemsky, …)
