Aaaand, I’m back. And truly flabbergasted. The file I sent you was to demonstrate that I had made changes to Header 1 but that the page number did not change. And yet, you are correct, it shows direct formatting and page 6 assigned. And I have several copies of the file (I usually work in .docx) and they all are the same. Gremlins?
Anyhow, I think I have reached the unmanageable situation you describe in a different section. I have 7 sections and 4 appendices and section 4 is the only one I have found this trouble.
I think my problem has to do with something called List Styles. And while they show up in inspector, I have not been able to modify them. Well, not quite true. There is an editing box but not the ability to tell it ‘Use this number!’
The problem shows up on page 27. Autonumbering has been proceeding nicely. We get to 4.7.4.3.1. And the next paragraph is a different subject and should be 4.8. But it comes up 4.1. I go Format>Paragraph>Outline and List tab>Untick ‘Restart Numbering at this paragraph’. It happily becomes 4.8, as does its first sub number (4.8.1). However I have to do this for each paragraph following. Luckily, I have a macro. Anyhow, I get thru the document, all is well. I save it. I reload it. Same problem in same place.
I’d hate to have to save it all out to a pure text file and start over but begin to feel that would be the best bet.
-----Paul-----
I obviously have something overriding something else but I can’t find it. AFAICT, I’m not using any Heading styles or anything other than LO-normal.
040-SECTION FOUR - PERSONNEL STATUS_EBC_Personnel_Handbook 20230505.odt (80.0 KB)
