I have created a pivot table using some numeric data. This results in a pivot table where the data is numeric (see the screenshot below: I have highlighted the values, and as you can see they are blue). However, when I created a chart for it, for example a histogram, the values are treated as plain text, which means that scaling is impossible:
If I choose a line graph, as you can see on this screenshot, the space between 7 and 7.5 is as much as the space between 8 and 9.5. How can I fix this?
If I choose an XY scatter graph, then I get this picture, where apparently the chart is using the line number or something similar; I cannot really tell. (Note: pivot charts do not have any possible settings regarding data.)
This is to be compared with the XY Scatter for manually entered data, which looks fine.
Please find here an example spreadsheet illustrating this issue.
