After copying paste on a Libre Office 5 document the correction of a dictation of the site “my dictée.fr” .Il appears on this document a curious thing? (attachment)
I thank you for helping me.
Cordially.
GH
Dictée.odt
Cordially.
GH
Dictée.odt
You did not describe the weird things happening. When I tried to open the attached document, LO Writer first objected twice that “path …/<doc_name>/content.xml does not exist” which would suggest that the *<doc_name>" (replace this with your file name) structure is damaged. Simultaneously, there is an enlarged icon of a blank document with an electric plug subtitled in red “Object 2” appearing in the upper left corner.
After dismissing the error dialogs and scrolling down then up, the big icon has disappeared and some grey text appears in its place.
Using the Navigator (Ctrl
+F10
), I see there are 2 “OLE objects” anchored to upper left corner of page. Selecting them and checking their properties with Format
>Frame/Object
, tab Wrap
and Type
, I get the explanation:
It looks like your OLE objects contain duplicates of other paragraphs. I deleted them and the document reverted to “standard” appearance. But only you can tell of the objects contain meaningful text. You may have used an unintended tool while copying/pasting the original text resulting in these OLE objects. Mimic what I’ve done and check by yourself.
Bonne journée.
If this answer helped you, please accept it by clicking the check mark to the left and, karma permitting, upvote it. If this resolves your problem, close the question, that will help other people with the same question.
